Sticky gas pedal - Page 2
Sticky gas pedal
Started by birdarchitect26, April 12, 2018, 06:50:58 AM
birdarchitect26
Thanks Bill, I sure appreciate your help in this matter.
I remove the cable from the engine and pedal assembly. The actual cable is just tough to pull, I'm starting to think the cable has a fray or maybe just old and dirty. I plan to make a small trip this weekend so I'll see if I can manage the pedal with some sort of strap to be able to pull it back if it sticks. I think i might pull the cable out and run a standard cable to follow with removal. I read someone sourced a Morse cable. I will do some calling around, I just can't afford to drop too much on the air throttle. I'll contact my local marine dealer to see if they have a similar boat throttle. I'll spam EBay for a used throttle, I will also call Luke just to meet him and get some verbal advice.
Jay
1973 MC7 Challeger
8V92Ta MCI conversion
Bill Gerrie
Your welcome Jay. Go to busnut.com as there has just been a discussion about the accelerator cable problem on there.
http://busnut.com/forum/index.php/topic,2520.0.html
daveola
I thought my accelerator cable (102A3) was starting to stick until some investigation showed me that it was the metal wall next to the pedal had come unattached and when I was driving (as opposed to manually pushing the pedal down to try to figure out what was sticking) it would push to the right and the pedal would stick a bit along the wall.  I reattached the wall and luckily my problem was solved without any cable work.
PP
Quote from: daveola on April 20, 2018, 03:51:35 PM
When I replaced all the flooring in the bus, I got real creative around the pedals with a scroll saw (entire driver's area for that matter) and when I pushed the fuel pedal down by hand, everything worked fine. First time I drove the bus after finishing the floor, the fuel pedal hung up. I realized after studying it for a bit that when you push with your foot you push slightly off to the side without realizing it. A little filing and some lube and haven't had a problem since.
