Will not air up
Started by edvanland, January 27, 2018, 08:44:37 AM
Dave5Cs
Reason I put the link to manual was basically so he could identify the airdryer he had being he didn't know which one it was. Sorry for the confusion. Ad2, Ad4 or Ad9
The way he is talking it sounds like he has a brake hose leaking with the nuts and farrows.all he has do it pull on hard with the nuts loose and it should come off the adapter fitting
Or he could try and see if full air pressure will disconnect it with nut completely backed off. Yeah, my dd3's had those hoses before I replaced them. The inside of hose can stick on the 1 1/4 long brass tube as part of fitting which provides support to inside of hose when nut tightens down on  compression ferrule.
Jim Eh.
Quote from: sledhead on January 29, 2018, 12:56:17 PM
try some soap and water in a spray bottle to lube up the fittings and it will help to seal when you put it back together
dave
It does make it go on easier and seal them alright but when the soap"dries" it makes it darn near impossible to remove that air line from the fitting (same problem he has now). Similar to putting handle bar grips on, it is the same thing.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
Dave5Cs
Jim Eh why would you want to put handlebar grips on your brake lines? :o ::)
PP
Quote from: Dave5Cs on January 29, 2018, 07:00:40 PM
I think someone needs to get a grip...
When assembling anything on the coach... remember who has to take it apart next time...
FWIW, I used a lick of anti-seize on the mating surfaces of all the brake hose connections, both the faces, and perhaps more importantly, up underneath, between the fitting and it's own hose. The ones I removed had to be cut out, they were fused with rust, both the mating surface, and to itself. Wouldn't turn at all.
Don't be sloppy, it would be bad form to send globs of anti-seize down the air hoses.
Happy coaching!
Buswarrior
Jim Eh.
So you can "ride on air" silly.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
