Using Ozite for ceiling
Started by Fred Mc, January 12, 2018, 11:39:28 AM
Fred Mc
I notice that a number of people used ozite for their ceiling coverage.
Is there a particular type?
How do you fasten it?
If gluing what kind of glue?
Thx.
Fred
robertglines1
The old fashion rubber cement--red/black can.  The new water based stuff sucks. It will give you a high if used in enclosed area..
Geoff
Geoff
'82 RTS AZ
Lowe's sells 3m spray ahesive that works well we used it in shop to install replacement headliners. Make sure you use black and green can, I believe it is #98. Don't use the red and black type, I believe is #89, as it won't hold up to heat.
Screw it on so you can easily remove it if necessary.
Fred Mc
Geoff
I have used spray adhesive on automotive carpet, spraying both sides, letting it get tacky, then pressing it together.  It does not hold under gravity!  The outdoor carpet glue is speed on with the correct size teeth then you have to use a carpet/linoleum roller tool.  I put mine on 15 years ago and have never had a problem.
Geoff
Geoff
'82 RTS AZ
I would use a marine vinyl Ozite is terrible to keep clean especially the white
Quote from: luvrbus on January 13, 2018, 06:34:56 AMI would use a marine vinyl Ozite is terrible to keep clean especially the white
       IME, it sucks up dust like a crack in the floor sucks up little screws that you dropped.
Lol, I guess shag carpet is out too.
Geoff
I have light grey Ozite on the ceiling and lower sides of my interior, and I don't have any of the problems mentioned above.  Ozite is like carpet, you can vacuum it or use spray carpet cleaner on it, but in 15 years I have never had to clean it.
Geoff
'82 RTS AZ
Jim Eh.
Thinking of using this as it seems to me it would absorb noise better than a hard surface covering.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
LOL my cleaning lady hates the stuff  :D
