Ethanol sucks
Ethanol sucks
Started by oltrunt, September 26, 2017, 06:11:36 PM
oltrunt
At least as a gasoline additive.  Now in good quality Gin------
From the "its always easier to to do it right the first time" file-----
I spent the day on my back under my bus draining the gas tank for the genny and modifying the fuel pick up line. Had I known 5 yrs ago what I now know about gasoline additives and their effect on non EPA approved rubber hoses I wouldn't have had all the fun. My buddy Tom and I both had our custom built aluminum gas tanks made at the same time. The welder provided a couple of "threaded bungs" on the side of the tanks near the bottom. He also fabricated filler necks and a large port on the top of the tanks for insertion of the fuel sender unit--a beautiful job. We'd both planned to use external electric fuel pumps and simply set a barbed connector into one of the bungs and went from there to the pump using flexible rubber fuel line (both from the same length of Gates Made in USA fuel line). About 3 weeks ago, Tom's fuel line gave up the ghost and puked the better part of 20 gallons of gasoline on his garage floor and out the drive. Long story longer, I was able to staunch the flow, clean up the spill and safely drain the remaining gas without burning Tom's condo complex down.
It didn't take me long to see the error in our design. If we'd have simply installed a
"straw" in the top of our tanks making sure none of the rest of the fuel line fell below the top of the tank we'd have been golden. Its that straw (though external) that burned up my day and back. All's well that ends well---ARRG!
Jack
