circuit boards
circuit boards
Started by bigred, April 10, 2017, 06:00:35 AM
bigred
Do any of you know of anyone on the Eastern End of the country that rebuilds/repairs circuit boards?? I have a place on the west coast that does this but would love to have someone closer.    Thanks in advance for your help!!!
Quote from: bigred on April 10, 2017, 06:00:35 AM
not sure but Steve at Jaytron Marine in Bradenton FL  has helped me. he probably knows someone if he can't.
worth a call.
OneLapper
Do you have an ECU problem?
OneLapper
1964 PD4106-2853
www.markdavia.com
bigred
Quote from: OneLapper on April 11, 2017, 12:24:36 PM
No .It is a board on CC Prevost conversion that most all of the 12v lighting run's through .One of the relay's on this board was fried when I got the coach and I would like to get it fixed.
RichardEntrekin
If you are sure it's the relay on the board. I can walk you through how to do it yourself.
It will take a magnifying glass for old farts like me. Read the number on the relay and google it. Of course buy two. The shipping charge will be more than the relay.
You will need a fine tipped soldering iron, some copper braid known as solder wick, and fine electrical solder.
Turn the board over, and locate the protruding prongs for the relay.
Hold the end of the braid over a prong, and hold the braid to the prong with the tip of iron. The solder will melt and flow up the braid. You may have to cut the used end of the braid several times to clean out one hole. When you have cleaned the solder out of all the relay prongs, it should easily detach from the board. If it doesn't come out easily, then clean up the prongs some more.
Put the new one in, and solder it to the board.
Hope this helps.
Richard Entrekin
2007 Marathon XL II
Ford Maverick Hybrid Toad
Inverness, Fl
bigred
Quote from: RichardEntrekin on April 12, 2017, 02:30:02 AMI took  a look at this thing the other day and just shut the door.This thing has a hundred wires that need to be marked (well ,maybe not a hundred but a bunch!!).The relay and a big resister show signs of being burned .There is even a burned place on the board itself .That is why I would like to get it to someone who can check the whole board out.I am pretty good with a soldering iron ,but when it comes to the finer points such as heat sinks and all that ,I'm lost!!!
Hope this helps.
dickegler
I had a similar failure with a board full of relays in an unfriendly location as well  I decided to use a automotive cube relay( mine was 24 volt)  removed the control wires from the board, and the 2 from the relay to the lights and connected to the cube relay. problem solved without trying to remove the circuit board.
Worked great.
Hope that helps
dick egler  atlanta, in  92 prevost/beaver conversion, N5333L
RichardEntrekin
Good point Dick.
There is a known relay failure on the air conditioner controls for the basement air units in the 2000 era Newells. The boards are becoming as scarce as hen's teeth. A few of us have taken leads from the circuit board to power a remote heavy duty contactor for the compressors. That seems to have cured the chronic circuit board failure.
Richard Entrekin
2007 Marathon XL II
Inverness, Fl
bigred
Quote from: dickegler on April 12, 2017, 05:42:14 PM
I had a similar failure with a board full of relays in an unfriendly location as well  I decided to use a automotive cube relay( mine was 24 volt)  removed the control wires fro m the board, and the 2 from the relay to the lights and connected to the cube relay. problem solved without trying to remove the circuit board.
Worked great.
Hope that helps
Think you may have the right idea !! I am going to check into doing it that way .These relays are NFC  MR331-N11 which must be a defunct business .I can't get a computer hit at all on them!!
