Almost completed my conversion
Started by Zephod, March 25, 2017, 05:57:43 PM
Zephod
Things left to do...
Jack the front end to check the kingpins
Add more cable fasteners to the underbody cabling.
Feed the cable from the solar charge controller through the floor to feed the spare cable in my cable cluster under the bus.
Replace the broken reversing horn.
Go through the control panel and replace the glass fuses I installed with automotive fuses and put fuses on my latest circuits.
Lower the brake pedal in order to make the brake operable without becoming a contortionist.
Replace the missing 4 half inch bolts that somebody took off the rear bumper.
Move the 5ah battery from atop a paint can st the back of the bus into an ammo can at the front of the bus.
Replace the missing wiper motor and make the new wiper pivot fit and add a new wiper switch.
Only about 5 months work there!
Once that's all done I'll apply to retitle as a motorhome.
I have to be speedy with the underbus stuff as the hornets want to build their nest again!
