4104 speedometer
4104 speedometer
Started by Nel, December 09, 2016, 01:37:46 PM
Nel
Anyone ever fix the original speedo on their 4104, mine hasn't worked since I got it, I see the electro mechanical sender above the transmission which I believe is for the speedo and have the original gauge in the dash. Is it usually a repairable reliable effort or time to move onto a gps unit, Thanks
4104-4519
West Nyack , NY
Check to see if the little drive pin is intact. They often will break. It should be 1 1/2 or so long. If it is broken, make sure the adapter isn't seized.
Nel
4104-4519
West Nyack , NY
dtcerrato
Nel
I have repaired our original speedo on the 4104 several times over the last 4 decades. Not the same problem every time. The sending unit on the transmission twice and more recently the electrical wiring at the dash. When it goes to working again, it doesn't for long! When it works its fairly steady but in some of the mph ranges it likes to bounce around. With all this being said, during the recent engine in-frame rebuild I left off the original speedo parts. I will eventually uninstall all the original speedo related items and do have some spare parts besides. If your interested in trying to save/restore your original system - you are welcome to all of the original speedo system incl. spare parts I have. I need to purchase a replacement speedo before I tackle the speedo head on the dash. In case your interested.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Nel
Thanks Dan, sounds like it might be better to look into an alternative speedo system too, I was hoping you would chime in since you have had yours so long, maybe there is a way to put a sensor on the drive shaft or one of the wheels,instead of a digital gps unit, I like gauges with needles anyway,Thanks
4104-4519
West Nyack , NY
Nel & Dan -
Perhaps this SpeedHut speedometer might spark your interest.  It can even be customized to make it look "period-correct"!
http://www.speedhut.com/gauge/GR338-GPS-14T/1/GPS-Speedometer-80mph-(w--turn-signal-and-high-beam)
Or the same unit without the turn signal and high beam indicator:
They also have tachs suitable for the two-strokes:
http://www.speedhut.com/gauge/GL338-TACH-06-HTZ/7/Diesel-Tachometer-4K-RPM
Nel
Thanks RJ, thats the way I will probably go ,looks great
4104-4519
West Nyack , NY
