Like Scott - Broken down at rest stop, Water Pump Seal
Started by Beachfinn, October 30, 2016, 08:14:46 PM
B_K
Trust that the guys @ S & S put the axles in correctly or you wouldn't have made it to FL!
As if they didn't get them right you would have gone nowhere! The long one wouldn't have been able to bolt up and the short one wouldn't have made contact with the differential and therefor e the bus would have just sat there.
Yes now is the time to get a new belt.
I know nothing about MC 5's but if you ask around someone will know the correct belt.
But I'd say chances are good you can get a part # off the one you have on there now!
:D  BK  :D
Beachfinn
So, the last part(I hope) to this story. Pulled both axles and cleaned them with lacquer thinner really good, nice bead of black rtv, hand tighten, sit for an hour and torqued down. One side leaked oil after few hours, with no oil put back in. Got the gaskets from MCI at hand now and will install in the morning, with small thin layer of rtv on gasket.
Fingers crossed,
Sami
Sami
'93 MCI 12
Full Timing Between Hotels and Coach
Need: Some bay doors, Front Signals, Steering Wheel, Drivers / Passangers Seats, Webasto, Stock Tinted windows
Quote from: Beachfinn on November 08, 2016, 04:52:28 PM...  One side leaked oil after few hours, with no oil put back in....
    Your axle is haunted!!  Only explanation.  (Best of luck with the gaskets.)
Beachfinn
It leaked from the same spot, where the pull out bolt holes are. The hub had pretty decent marks from over the years, hence bo seal. The gaskets cover the three holes, so it should be fine ..  me hopes
Sami
'93 MCI 12
Man, I feel like we jinxed you...you should never have shook my hand man... :-\
Beachfinn
lol bud, I'd never think of that. I will '  shake your hand plenty times in future. It's just bus life 🤓
Sami
'93 MCI 12
kingfa39
I did the same thing as bevens6 did , replaced the seal without removing the pump in the yard in about a hour, low cost seal. no big deal, 8 v 71, never had another problem
