Moving along on the bus
Started by harleyman_1000, August 09, 2016, 10:24:39 AM
harleyman_1000
Bus inspected, and licensed yesterday  ;D bus drove and ran good, Temp stayed around 170 to 180. I will be hooking up the pump and water line for the misters today. Another small bite  ;D
Scott
St.Louis Missouri
ScharpeStGuy
Harley Man,
Good luck with your bus/project. I am in the process of acquiring a 1985 Eagle and appreciate your sharing. What pump and misters are you using and what are you using to activate the misters? Any chance you could put together a DIY with pictures for ones that come behind you attempting to do the same? I will try and do the same when I pickup our Eagle.
All the best and what is next after the misters?
Purchasing a 1985 Silver Eagle Model 10
Huntsville, TX
Best and cheapest insurance you can get for ( those times) Do a search in the archives.
