Back up Camera Question
Started by Nick Badame Refrig/ACC, January 16, 2007, 06:23:37 AM
The camra arrived this afternoon...
I'll see if I can get it hooked up tomorrow.  I'm excited!
Just mounted the new camra,
I'm impressed..   It has a wider angle then my old one.  And is very clear compared to the old cam.
The color has more detail, and I will wait until tonight to test the night vision..
Here is a pic.
H3Jim
Nick, is that the R & M fiberglass pod that the camera fis in?  HOw did you mount it inside?
Jim Stewart
Hi Jim,
That was the tricky part....   I mounted the new cam to a 3/4 piece of plywood so it would
pertrude through the pod. Then I purchaced a roofing boot made of rubber, and cut a rectangle hole
in the end so the camra would poke through. Then the wider part of the boot sealed the pod hole perfectly.  I impressed myself....
It's fully adjustable in all directions.
H3Jim
What's the plywood fastened to?
Is there a hole in the bus cap to access from the inside?  or do you have to take off the pod?
Jim Stewart
Jim,
The plywood and camra is fastened to my orriginal cap which is still under there.
And the R&M pod is removeable.
I have the same camera pod. Just mounted it last week. I riveted mine, so I could take it off when needed. I also mounted two back-up lights, one on each side of camera. Came out pretty good. I would share a picture but some of our stuff is in California still.
Looks good Nick!
Happy Trails,
H3Jim
Paul, where did you get your lights from?  The guy at R & M said that I needed to find some that would clamp on around the rim, and i have not seen any in the autoparts stores around here.
Great idea guys about mounting it with screws or rivets so it can be removed!
Jim Stewart
H3Jim
I mounted the lights and camera before attaching the cameral pod. I bought my lights at Harbor Freight for around ten bucks. I just mounted everything to the rear cap.
Happy Trails,
mc8 tin tent
Nick
Im not for sure but,my family got me what seems to be about the same camera ( only with black case) the spec. were the same .
  we/they got it from Pivco( an after market auto body supply for about 75.00)  may be worth a look????
    Dwayne  mc8 tintent
