stripped studs
stripped studs
Started by silvereagle1964, July 21, 2015, 07:24:51 AM
silvereagle1964
in the process of getting new tires put on my 64 01 eagle drive axle, I now need to
replace two drum studs on the left side. anyone know the info I need to get the studs ordered?
do I also need to order inner and outer wheel seals? if so what are the numbers for those any help is greatly appreciated. I guess I also need the mfg of the drum, parts, etc.
mark reid
260-343-8905
thanks
blue_goose
Mark I don't have the answer for you, but if you make the same post at thehttp://eagles-international.net you will get an answer.  The studs are the same as used in trucks and you will need new seals.
Jack
can't get a tread chaser or a thread file on it ?
I sent you a PM. I have the parts manual on pdf for your Eagle.
