Diode for Battery Bank Merge Solenoid
Started by David Anderson, October 30, 2007, 05:47:18 PM
Red Rider
I ganged three ,300 Amp golf cart solenoids on a buss bar .Seems to be doing just fine however I'd need to run that set up for several years like some of you have to see if it will really lasts. If I had to do it over gain I'd get a "Smart Solenoid" (Google) that takes out all the guess work and the "oops I forgot the switch" out of the equation.
Mike AKA; Red Rider 4106-1885
gmcbuffalo
What's draining your batts that you need this so often?  Should be looking at that problem first.
