genrator question
genrator question
Started by uemjg, September 04, 2013, 03:43:48 PM
uemjg
I was told today by Wrico that my I needed to make sure that my generator has the neutral bonded to ground.  What is the best way to do this?
The easiest way is to look for the connection between the generator chassis and the neutral wire.  If you can't see one, use a DVM set on tone to check for continuity between neutral and ground.  What kind of generator is it?
uemjg
uemjg
Quote from: bevans6 on September 04, 2013, 04:11:20 PM
So as long as there is a connection between neutral of the generator head and the generator chassis then is that neutral-ground bonding?
bobofthenorth
Quote from: uemjg on September 05, 2013, 12:08:15 PM
NO.
This subject has been discussed to death in the past.  You need to use the search function and come back when you can ask a question that hasn't already been asked and answered 100 times.
R.J.(Bob) Evans
uemjg
Quote from: bobofthenorth on September 05, 2013, 01:02:29 PM
NO.
Bob,
Thanks for taking the time to respond to my question, but since I was directing this at bevans6 then anything other than a positive response is not welcomed.  what you don't know is that i have done the serch and the results have not really answered my question, so hence I am asking again.
lvbob
1981 Eagle 10/15 series 60 740 auto
