Lights for toad-
Started by ChuckMC8, December 04, 2006, 04:03:07 PM
ChuckMC8
Hmmm......My bus has seperate tail, stop, and turn signal fixtures. I want to use a fixture on my toad that just uses a single bulb like a 1157 configuration for the tail/stop/turn signal. How do I make that transition? thanks
Len Silva
You can buy an adapter at anyplace that sells hitch hardware, even Walmart I think.
Len
I originally had my car (MB Turbodiesel) wired for lights, but with the diodes, adaptors and such, never was able to get it working correctly.  So I bought two sets of magnetic LED lights.  I used a 5 prong plug and wired the lights myself.  It takes all of about 5 minutes to set it up.  Now my car lights duplicate the bus lights and if I have to tow anything else, have the lights ready to go.  And of course they work right since I did all the work myself (or it always seems to be that way when someone else tries to do the work for you).  Good Luck, TomC
gumpy
Len Silva
Quote from: Len Silva on December 04, 2006, 04:28:36 PM
Len
Sorry Chuck, I didn't pay attention to the "MC8".  Since you need to convert 24v to 12v as well as separate stop/turn to combined stop/turn, Gumpy's relay system is the way to go.
If you had a 12v coach, the adapter would be all you needed.
Len
