Leveling on a GM (when parked)
Started by Geom, July 01, 2013, 07:24:37 PM
Geom
Quote from: 2xclutchin on July 02, 2013, 09:28:14 PM
So, any suggestions on how to get the springs on my bus to help level?  :P Hehe
Ha! I'm sure we can!  ;D
We just have to put some thought into it. I'm sure we can come up with something. Although afterwards, I can't promise they'll do anything they were originally designed to do before.   :P
1966 GM 4107
6v92 Turbo
V730
Dave5Cs
Geom, MCI's are the same as Gm's they have always had air bags and the tripod also. I left my leveling valves in but plugged the air lines to them. Disconnected the air line to the air Beams. Gms IIRC don't have air beams. I then connected air lines to each side air beams and ran those up to the front for air fill lines..
I hooked the fronts up independantly also and then ran all 4 lines to the gauges and air buttons on the Ride Rites. 1 line to each of 4 gauges. each also has an exhaust line within the down button. You also have to run 1 line from the accessory tank up to the gauges and it just splits off to each gauge for filling the bags.
If you need air in any corner that has 2 bags each you just push the button for up or down if you need less. It take about 10 minutes to fill all if it is air down but just a few minutes if you are only adjusting. When driving I keep 80 in the front and 90 in the rear. Its is nice and smooth as if you are floating on air. Oh wait you are, LOL
You could also use 1/4" ball valves and good small air gauge and keep the tripod with 3 units instead of 4.
Tom , nope no tweaking. A little at a time. I guess if you had a 1 inch airline and a big compressor it would fill very fast and could be a problem then, but not with 1/4" lines and 1/8 " valve lines on the back of the gauges.
Dave5Cs
Geom
1966 GM 4107
6v92 Turbo
V730
sledhead
Just got back from camping at the lake this weekend . I had to lower the front right bag down to 10 lbs and front left to 60 lbs , rear right to 30 lbs the rear left up to 90 lbs . all to make level . After start up back to drive level front 90 lbs rear 50 lbs  now that is the height of the bus before the change . In 6 years no problems with stress on the body . It sounds like Davec and I have the same set up                    dave
dave , karen
PSmith
I'm starting to get a headache ::).
I retained factory system when driving - then individual 'push-pull' valves when parked 'like camping' on unlevel ground.
rears are normally tied together, but separated when parked.
fronts are normally separate when driving or camped.
bottom line:  Level it with manual valves when parked.    When ready to drive away - just flip a switch and it levels using factory leveling valves. Wa La
5) 'bubble-free' solenoids used.
Stays level about a week when parked - then we need to air it up again.
We could block it - that might be better for longer stays.
Dave5Cs
After disconnecting leveling valves I don t lose air anymore. Yes I have to adjust back to level but that is no big. If a spot is really steep  anybody will have to  use a few blocks but that is a given.
Dave5Cs from Galaxy S III
Our 4104 had the aux leveling system on it for years and never had any issues with body twist, even on some extremely slopey ground. 4 corner adjustment, while still could switch back to automatic leveling system. System uses a auto-manual switch, 4 air pressure gages and 4 push-pull valves to control each corner. Went back to three leveling valve auto control on automatic position. Was sold by an FMCA member years ago. Called Level-it. HB industries sells/sold a similar system. I have gathered up the individual components for the same setup for my 4905.
uncle ned
Huggy has a four corner leveling system that works when parked and goes back to the original when on the road.
a "level it" by Red Rideout. haven't heard from him in years.
Also as a four corner hyd. system that I use if the place is to unlevel to get level with the air only.
also use it to just make the coach steady when parked.
I have also removed the back door and replaced it with a window so I can get air through the bed room at night.
It also has a big 6v92 and 730 hung off the back.
Has been that way for years and has not broken into yet.
uncle ned
4104's forever
6v92 v730
Huggy Bear
Ed Hackenbruch
We also have the Level-it system of 4 gauges and 4 push/pull valves. Self leveling was taken out. Been fulltiming since Jan. 04 with no problems, if needed will also use a run up ramp, but try to find sites that are close to level. Don't know how long ago the PO put the system in.
