part number for Stemco oil hub window?
Started by bevans6, May 22, 2013, 08:28:50 AM
I broke one of the sight windows on the oil hubs on my MC-5C.  Stemco was totally useless at getting a part number for me.  Does anyone know the part number to order for that little sucker?  It is 2.75" in diameter and .190" thick at the edge, with a standard fill plug hole in the middle.
Thanks, Brian
robertglines1
Brian; I bought two new hub covers complete last week at truck pro for around $10 each for the 98 XLE: sort of shocked at low price. Included new gasket's  Bob
www.ryderfleetproducts.com I don't think they service the plastic part only the plug so many different models to choose from I would replace both, the plastic get hard and brittle sooner or later the other side will break as Bob said they are cheap at truck supply places
Well, I got somewhere.  I found a Stemco PDF with dimensions on it, and the MCI front hub dimensions are 6 on 6" bolt circle, 3/8" bolts, and the Stemco part number is 343-4080, which crosses to the MCI part number 15C240 and 15002400.  Around $35 at Ryder, thanks for the link.  The window kit is 359-5999 for the 2.75" window, which is what the hubs I already have need.  So I will just need to source a window kit, and that is a lot easier with a part number!
Zeroclearance
For those that have a later Prevost and MCI.
The Stemco window that measures roughly 3.60"   The repair kit is 359-5912   The complete replacement hub cap seal assy is part number 343-4249..
Clifford these are the correct ones for your 2002/2204 H3..  Fleetpride has them cheaper than Ryder..  I think that I paid $27 for the complete unit.
Zeroclearance
FYI, the RED plug is part number 359-5915  For those that have weathered plugs.
