What to look for in a used mci 102?
Started by Jnbroadbent, February 20, 2013, 03:28:04 PM
Jnbroadbent
Hopefully checking out one tomorrow, it's had not been converted and I don't its history. Rust is an obvious... But other then that any specific problematic areas I need to really look over? I belive it has the 6v92 and the 4 speed.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
lostagain
I looked after the hockey team's 102D3 for several years, so have some experience. The biggest concern always was with corrosion. Even though most of the bus is built with SS steel. The problem areas were mostly electrical: the panel outside under the driver's window always had moisture in it, and it was a constant thing fixing ground connections on the bottom of it. Also the terminals in the batt. compartment: to the batt. equalizer and the batts themselves. The clearance, turn signals and head lights were a regular issue too, mostly to do with grounds, and sockets. Another area that gets a lot of moisture is the rad and inter-cooler compartment at the back above the engine. Electrical terminals and fan clutches were susceptible. Had to replace the rad once because it rotted out. All the door hinges and latches also would need regular lubrication. The Webasto wiring was also something I was into often because of corrosion. That bus was driven in the winter mostly in S.E. BC and WA state, so lots of snow and slush. Otherwise a great bus, all SS steel, and with a pre-EGR S60 and 7 speed manual Eaton/Fuller was a hot rod: go up mountain passes with the cars.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
lostagain
Oh and I remember now: look at the baggage doors locking mechanisms. The rods on the inside of the doors that are turned by the locking handles, are secured by aluminum hardware fastened to the steel doors, and it corrodes and tears off the door. I had to weld some back together. A PITA because you have to take the door off and remove the sheet metal liner to fix it.
If your bus hasn't seen too much winter, you won't see any of that.
JC
JC
Blackie AB
Get the bus with the right engine/transmission setup. I don't consider a 4spd manual workable in a 40ft bus. I realize many have them and are making them work. If you want a manual transmission, at least a 6 or 7 spd should be used-a 10spd even better. Then you have really great control over the bus at slow speeds for getting in and out of a camping site, backing up a hill, or even starting on a hill.
Personally- you quite simply can't beat the driveability of the Allison transmissions. Granted they use a bit more fuel-but just drive one after driving a manual bus, and you'll see where I'm coming from. I drove 13spd in my truck for 21 years and 1.3 million miles, and I switched the 13spd for the HT740-what a difference-wished I had it when I was driving. Good Luck, TomC
Jnbroadbent
Quote from: lostagain on February 20, 2013, 06:15:02 PM
JC
Thank you! I got to do a walk around and check all the control panels. Everything looks good. They have maint records from a prevost place in Orlando and kept up maint. and logged everything. So far looking good! Didn't get to take it for a spin, we will over the weekend.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Jnbroadbent
Quote from: TomC on February 22, 2013, 08:15:51 AM
Tom, it has the allison ht740.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
Hi Jon,
The 6V92 will be real close in power as your 871.
Deff do an oil analysis, check for firm shifts in the HT-740,
check baggage doors for rust, check front air bag beams for rust,
road test for handeling and power and issues.
Good Luck
6V-92TA mechanical and Allison HT740-great combination. With 9G90 injectors you can get 350hp and 1000lb/ft torque. Enough power for what we do. It will slow down on hills, but no slower then big trucks do these days. 6V is cheaper to run and maintain then the 8V. I would get that power train. Good Luck, TomC
sledhead
If I had of waited a couple of years to buy a bus my choice would have been a 1994 or 95 102 d with a dd 60 series,a 6 speed trans. still 40' but more updated eng,trans. Last 2 years before the 45'ers                       dave
dave , karen
John316
Quote from: sledhead on February 23, 2013, 10:55:51 AM
If I had of waited a couple of years to buy a bus my choice would have bee a 1994 or 95 102 d with a dd 60 series,a 6 speed trans. still 40' but more updated eng,trans. Last 2 years before the 45'ers                       dave
Dave, not pickin at you, or anything. However, ours is a 95 DL3, and it is a 45er. We like it. S60 and Allison B500.
sledhead
I like the 40'er over the 45' because the provincial,state parks we like to camp in have more sites , some only allow 40' max
    dave
dave , karen
Course if you can find a D model with a Series 60 and Allison B500-that would be prime. I would pay $10,000 extra for that engine/transmission. Plus-the D model is still in production. Good Luck, TomC
Jnbroadbent
Quote from: Nick Badame Refrig. Co. on February 23, 2013, 04:11:59 AM
Hi Jon,
Good Luck
Nick,
  Finally got to start it up and really check everything out. Rather quick and I'm going back on Tuesday...
White smoke on start up all the way until we pulled out of the Parking lot 15 mins later. Wasnt too thick and smelled like fuel (rather then sweet like coolant) I didn't check oil or coolant. Next time definitely. Went around the block, didn't even get to really open it up, came back and most of the smoke had cleared. Very concerning though...
No rust in bays. Oddly though, underneath the vertical support columns in the cabin, there was rotted wood in the bays. I poked a hole and could not find any trace of water. Small areas, like 4"x4" very concentrated.
All the bags seem to be pretty dry. Otherwise almost no rust anywhere.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
White smoke just could be from long periods of idle take a run for about a hour see if the black smoke appears or go back the next day and start in again after your run.
Lot of time you get white smoke in the morning from dribbling injectors overnight but it clears up in a few seconds after start up that engine may have problems take it to a dealer money spent now will be less than what it could cost down the road by far JMO
