Direction of Crank Rotation
Started by Craig R, August 08, 2012, 11:44:25 PM
Craig R
I recall that the cranks some V-71's & V-92's rotate clockwise while those of others rotate counter-clockwise.
Could somebody quickly school me regarding which is found where?
Old MCI engines spin which way?
Old dogs mounted transverse spin which way?
Dump truck and COE engines spin which way?
The twin diesels pushing power boats spin which way?
Thanks. Craig
thomasinnv
I do believe the only ones that spin backward (lefty) are the GM transverse engines (sidewinders), and some marine engines from a dual engine setup. MCI's, Eagles, Prevosts etc. are all right hand turning engines.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
wildbob24
Craig,
MCIs are right handers(clockwise)
Transverse GMs are left handers(counter clockwise)
Dump trucks and COEs will be right handers
Not completely sure about twin-engined boats, but I believe they use one of each.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
Boat are right handed engines they reverse through a gear box
lostagain
Clockwise rotation is looking at it from behind the bus. Or from the front of a truck.
What can get confusing is that the DD service manual looks at things from the back (flywheel end) of the engine. Spins counter-clockwise at that end.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
thomasinnv
Quote from: luvrbus on August 09, 2012, 06:57:55 AM
Clifford I thought some of the older twin screw setups had one turning each direction? I know I've seen a few backward turning marine engines on the Ebay.
EDIT: On second thought, you know people often refer to a GM backward rotating engine as a left handed rotation, when they are actually a right hand rotation as seen from the flywheel side. Like JC pointed out the rotation is determined from the flywheel side...thus a MCI, Provost, Eagle and all OTR trucks would be a left hand rotation. GM transverse engines would be right hand rotation.
I did some googling and found some information saying that marine engines can be found in a right hand or left hand rotation, but then I also found some information that said all I/O engines are left hand rotation only, period. What's a guy to do if he can't trust the internet? LOL.
1998 MCI 102-DL3
Some of the old marine stuff were but all the modern and some of the older stuff stuff runs through a gear box for direction fwiw the twins and the quad engines where left and right running engines into 1 common box and 1 output shaft
Don4107
Not Detroit but my boat with small block Chevys has a counter rotating engine.  They do it by gear driving the cam shaft so it turns normal direction or opposite the crankshaft. That keeps the distributor and oil pump turning the normal direction.   Starter, water pump, crankshaft seals, camshaft are special.  The velvet drive trans will work either way if memory serves by reclocking the input cover.
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
Any of the 2 stroke Detroits could be reversed for twin engine application on a boat.  Most engines now are not reversible-hence the opposite rotation is done at the transmission.
Sort of interesting-a few years ago I was on a 90ft crew boat converted to a live aboard dive boat that had 3-12V-71TTA's that all turned the same direction, and used 3 bladed props instead of 4 bladed.  It was very smooth.
Good Luck, TomC
Lee Bradley
Some of the old ferries in the Washington State fleet had direct drive; engine to propeller. Shut the engine down at the dock and start it in the opposite rotation for the return trip.
