8V71 Starter LH
8V71 Starter LH
Started by 06 Bill, November 08, 2006, 06:01:51 AM
06 Bill
Is the starter on a 8V71 12v Left rotation & 12v Right rotation wound in the same direction.
The part #s for a V drive & a T drive seem to be the same as far as the armatures go.
The splines are straight not spiraled as on a dedicated rotation armature.
Thanks in adv 06 Bill
busguy01
On auto type starters you can change rotation by clocking the brush holder to a different slot on the case.  I am fairly  sure that the same holds true on any DC starter or motor. You are changeing the relation of the brushes vs the field.
JimH
Started with nothing - still have most of it left!
1963 Eagle 01 with Detroit 60 series done (Gone-sold!)
MCI EL3 in progress. raised roof & Slides
2009 Revolution 42 Sticks and staple
Summer - Yankton, South Dakota
Winter- Sebastian, Florida
RTS/Daytona
But remember - the clutch on the starter gear has to ratchets in the opposite direction
