Eagle Model 01 front wiring diagram
Started by sunlovers, June 10, 2012, 02:29:28 PM
sunlovers
Good afternoon all!
I am in need of the wiring diagram that is inside the front circut box by the drivers seat. As I understand it is attached to the inside of the door.
I do have a complete wiring diagram of the bus but not of the front circut board.
Any help would be greatly appreciated.
Mike
67 Eagle Model 01
8V71 4 speed
#7080
Mike & Kathy Mingus
1967 EAGLE MODEL 01 SE
4 Speed Manuel, 8V71
Ser. # 7080
Bishopville,SC
I never saw a diagram in the front panel on a 05 or a 01 only numbers on the wires and bars just follow the numbers in your manual yours should be the same as the early 05's, Brownsville built Eagles will be different 1976 and later
Just a FYI (info) my Eagle has a schematic in the relay box under the toll window and another in the relay box in the rear engine compartment, I thought all the coaches had them...i learn something everytime I log on here
PS mine is 19952 some say 1977, Title says 1978.
That is a Browsnville built Eagle not a Belgium,Willie needed that his vision got a little blurred at times from the left handed smokes ,none of the Trailways Eagles I seen have it except a few 10's and the all the 15's it was probably a option from Eagle
 i should photograph them and figure a way to get them transffered to a metal plate or decal....maybe i could trade for a GVWR tag...
sunlovers
eagle19952,
can you get the front circut panel door off and copy the diagram on a full size copier? that way you could then scan that copy into your computer and then e-mail it out to anyone that might need a copy.
Clifford,
In my front circut box the wires do not have numbers but there are several bars that run up and down with numbers on them. would these numbers match the numbers that are on the complete bus wiring diagram?
thanks
Mike
Mike & Kathy Mingus
Ser. # 7080
Bishopville,SC
the "panel" is more like a shoe box cover...I don't think a copier can "see" that far....let me scratch my noggin...
chev49
use a good camera with a sd card and post... ;D
Len Silva
sunlovers
WOW!!!! Thats it! Where did you find that? That should solve all my problems....LOL
Mike
67 model 01 SE
8V71, 4 speed
#7080
Mike & Kathy Mingus
Ser. # 7080
Bishopville,SC
here is one from a GSA model 10 ? just to show that some models did have them....mine has the oler style "horn type" relays...vs the bosch type...still figgerin on mine to post... ;D
Len Silva
That's got to be the cleanest Eagle electrical compartment I've seen in a long time.
possibly that is because it has not been busnutted... :-\ ;D
