Anyone use one of these?
Started by Eric, May 30, 2012, 10:59:31 AM
Eric
Len Silva
The 1 amp idle current seems a bit high to me.  Otherwise, it will probably do the job at a pretty low cost.  It does not have an AC pass through so you will have to move the refer plug every time you connect to the pole or generator.
It is also not designed for a permanent hardwired connection, only plug in.
from Amazon.com, check to be sure that you get a good one...
ps the other reviews were all 5 star....
This review is from: Ramsond SunRay 1500/3000 Watts W True Pure Sine Wave Power Inverter Generator (Remote Starter Ready) Back Up 12V DC to 115V 60Hz AC RV Truck Car Solar Off Grid ETL Listed to Conform to UL 458 STD
Works ok, but the voltage is a little on the low side and can be seen in lights. It runs about 109 volts without a load and 105 volt with about a 100 watt load.
Lin
Len- You could use an automatic or manual transfer switch.
Eagle- Even though it says it is pure sign wave, inverters really only approach pure sign wave, so the voltage measurement given in the review may be wrong if it was not taken with the correct type of meter.
Quote from: Len Silva on May 30, 2012, 11:22:05 AMThe 1 amp idle current seems a bit high to me.  Otherwise, it will probably do the job at a pretty low cost.  It does not have an AC pass through so you will have to move the refer plug every time you connect to the pole or generator.
      There are many features on a "full-integrated" inverter that are not included on this one.  There's no charger for batteries and no tie into batteries (expect for the 12V in and 12v output -- both of which look pretty flimsy for a 1500/3000 watt inverter); no arrangement for control of anything other than "bar-graph" readouts, plug in connections that are totally against code about everywhere, and many others; I'm also a bit afraid of it's standby control if it uses 1 amp at idle.  There may be some "odd-ball" uses for it but as a basis for any kind of central electrical system on a converted coach, it wouldn't work for most people.
      Besides, I've seen *very few* people who had anything to do with Ramsond products that came away with anything good to say about the experience.
Utahclaimjumper
Bruce,, you think that explains the" special low price"??>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Bus Busted
So what are the guys "in the know" using? I've been using two 1500's for some simple stuff, but I too am ready for something for the final build...
1985 Eagle waiting repair of burn damage
1984 Eagle Model 10, just started conversion
1986 MCI 102A3, seated when bought, conversion on hold until Eagle is done
The "in the know" guys are using pure sine wave inverters with some great automatic electronic features...but seriously, the cost of 5000 watts of power at 24 volts (a number our bus alternators/generators are capable of) in an inverter is just ridiculous. By the time you pay for a 5000 watt pure sine wave 24 volt inverter, you're well on your way to having a nice efficient liquid cooled diesel genset that doesn't stop generating power when the bus is turned off. I'd love to get inverters for ours, but I just don't idle all night at truck stops because of wet stacking and engine heat warming up the bedroom a lot during summer nights. So I run a quiet generator...works for us...
Quote from: Utahclaimjumper on May 30, 2012, 12:27:37 PMBruce,, you think that explains the" special low price"??>>>Dan
     Few features, not legally useable, poor reputation, ??? reliability -- nah, couldn't possibly be that!
Lin
I  thought he was just talking about running a frig on it.
desi arnaz
I have one of those and one of the diesel generators from rand some. The inverter seems to be ok but I had nothing but trouble with the Bennie it wouldn't start at first and then when it did start it would sputter until I put. An external fuel pump on iit. It seems to work now. I got both for free for all the trouble I had with the company and amazon refunded another $800
On top of that to me, seems the right hand didn't know what the left was doing...so I got two refunds,I told them. They did this and never heard back again.
thomas f  Bethlehem n.h
