hvac hose ducting
hvac hose ducting
Started by garhawk, January 18, 2012, 12:32:41 PM
garhawk
Anyone have a lead on hvac hose ducting for 1989 Eagle - size is 3.5" ID.
I've tried using 4.0" but, the stiff wire inside the hose prevents any reasonable sealing around the 3.5" flange.
Also, could use a couple finished type vents in the same configuration.
gary t'berry
Eagle Mod 20 DD ser 60 w/slide
GMC RTS 102"  40er (in progress)
That is automotive size find you a Clevaflex dealer or have a shop make you reducers
garhawk
Thanks Clifford.  That dit it!
gary t'berry
