bus makeover
bus makeover
Started by Ace, November 07, 2011, 03:22:16 PM
Ace
Today I started the makeover on interior of our bus. Got all the old carpet out along with the padding and the Gazilli staples that yours truly put in. ouch!
Anyway the passenger seat, seat belts and steps at out. I'm ready for 3/8 plywood for the LR area which will bring that up to the same height as the kitchen. Then 3/8 Hardy board, then ceramic tile from the bottom step up thru the mid steps  and then thru the LR, kitchen and bath stopping at the br door.
U plan on installing the 17 inch tile on a 45 degree angle at a half drop. Hopefully this change wil be easier to keep Buds hair in check. He sheds like a bear!
Also our full size bed will be updated to a queen in the br and more space added for hanging clothes!
If the rest if my leds would show up, I wouldn't have started this until 2012 but it us what it is. Next plan us to remove the oem a/c and make that bay a tool bay! :)
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
MEverard
It sounds like you have your work cut out for you.
Good Luck,
Mike
Mike Everard
1960 GMC PD4104-4520
Antioch, CA
What starting a major project like that so close to the Arcadia rally?
What will you do if you don't get it done in time! ;)
Ace
Probably do like Belfert and come here for help!
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
