Strange Tire Wear
Started by RJ, December 30, 2017, 07:52:50 PM
He could try a harder rubber compound tire like a BridgeStone but he will  give up the soft ride
Dave5Cs
RJ also check your tow bar for level or within 3inches of level. It can have a big difference as in push down on the front of the car or lifting up in a hard stop as well as traveling around corners. Shocks also need to be checked. Our front tires one shredded and the other started showing steel wire belts at inside edges the back ones were fine. Now we have traveled 3 times as far on the new ones and no problems. the back hardly show any where.
Geoff
So, RJ,. What have you done, if anything, about your toad tire wear??.
Was your car weighed down causing the inner tire wear or what???
Inquiring minds want to know!!
Geoff
Geoff
'82 RTS AZ
