MOVED: TRAVELING WITHOUT THE MOUSE
Started by HighTechRedneck, September 19, 2011, 10:48:17 AM
HighTechRedneck
Quote from: boxcarOkie on September 18, 2011, 06:30:21 AM
Quote from: Lonnie  time to go on September 18, 2011, 02:25:36 AM
No offence please but should this be in the off Topic section
None taken, it kinda morphed into something totally different, a common occurrence around here.  You are the first person in over 400 to see it that way.  Check the box in the lower right hand corner (report it to a moderator) and they most likely will accommodate you.
BCO
This thread has drifted all over the place and since a few have done as suggested, it probably is time for it to move over to the Off Topic board.  Carrie awn.   ;)
This topic has been moved to Off Topic.
http://www.busconversions.com/bbs/index.php?topic=21573.0
