Possible Genset? - Page 5
Possible Genset?
Started by gulfyankee, August 28, 2011, 02:05:45 PM
Lin
I know that this is where everyone does it there own way, so I guess that if you are happy with it, it's okay.  It looks unsafe to me, and I love shortcuts.  The comment that you can't touch the door without gloves sounds like something to be concerned about.  We also have a very, very, old 7.5 Kohler gas generator.  It is reasonable quite, runs beautifully, and does not noticeably raise the temperature of the bay door.  If this one poops out, I would tend to look for another old one that is designed for the task.
Me I just think too much is put into a generator being approved for RV use,I been around Wrico generators and others for a long time never have saw Wrico state approved for RV use and he has sold 1000's for conversions over the years
Len Silva
I agree, there is no reason that a Contractor generator cannot be modified to function safely in an RV environment.
It only takes a little common sense, electrical knowledge, adequate cooling air supply and exhaust and careful monitoring of temperatures.
I would not, under any circumstances, use such a generator in a bay without a remote fuel supply.
OSHA sets the regulations for contractors generators not that need that much clearance,I think it is title 29 same applies to a diesel or gasoline generator on a job site and the manufactures are required to put the refueling and clearance stickers on those units been there done that with OSHA lol
robertglines1
So modify for RV use.... I can buy that.   won't question quality --that is for buyer to determine-bang for the buck.  Be safe!
Lin
I am not saying that a contractor generator can not be adapted for RV/marine/enclosed use; at the core, a generator is generator.  However, the ones constructed for our use have the needed adaptions and modification done as part of the manufacture process.  You can theoretically build your entire genset from scratch or start with a contractor style generator, where most of the work has already been done, but from there I would say that you should upgrade it to make it completely equal.  This would include a remote fuel source, proper muffling, safe exhaust discharge, an enclosure ventilated well enough that heat is not an issue, and probably some things that don't come to mind right now.
Quote from: Lin on September 06, 2011, 11:42:16 AM
I am saying that a contractor generator can not be adapted for RV/marine/enclosed use; at the core, a generator is generator.  However, the ones constructed for our use have the needed adaptions and modification done as part of the manufacture process.  You can theoretically build your entire genset from scratch or start with a contractor style generator, where most of the work has already been done, but from there I would say that you should upgrade it to make it completely equal.  This would include a remote fuel source, proper muffling, safe exhaust discharge, an enclosure ventilated well enough that heat is not an issue, and probably some things that don't come to mind right now.
Probably a long pull cord coming up through the floor to start it. ;)
JT4SC
dougyes
Regarding the Gas Onan on LA craigslist: Onan had problems in the 90's with generator magnets ungluing and flying around making a mess. I saw it happen myself. They did not warranty the problem and everyone was stuck with a rebuild bill. Check the manufacture year on that one.
jbnewman
How about this generator? It apparently comes with a bus...   :o
http://richmond.craigslist.org/tls/2577945472.html
-jbn
Justin
Chicago, Illinois
1964 PD-4106
It seems to me the only real problem here is keeping it cool which a good blower would take care of.
Fuel lines to RV specific gensets can break and burn just as easily as this one so don't see that as a unique problem.
The hot floor might be solved with a good blower, if not more insulation would do it.
I'm in the process of installing a 326 CFM blower on my newly installed Westerbeke boat genset because it gets pretty hot without the original water cooled exh manifold.
Quote from: jbnewman on September 06, 2011, 05:42:53 PM
-jbn
jbn it seems like for what it is that generator is overpriced and on top of that your stuck with a bus to get rid off! ;)
