Forum Navagain changed?
Started by Tikvah, August 24, 2011, 11:48:09 AM
Tikvah
Has the navagation changed on this forum or is it just me?
I used to log in and see a list of available forum pages... I don't remember exactly what, but for example... there was the forum rules, Bus Nut Pictures, Discussion Forum, Things for sale, etc.
Now I log in and see "forum stats" and have to click some weird likes to get to the Discussion and simply can't find anything else.
Am I doing something wrong or has something changed?
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
HighTechRedneck
No changes lately.  It sounds like you may have accidently clicked the little "-" at the left end of the bar that says "Bus Discussion" when on the forum's home page.  ( http://www.busconversions.com/bbs/index.php )
When that section is collapsed, you see a "+" sign to the left of "Bus Discussion" and then it jumps to the Forum Stats section.  Click the "+" and it will expand it back open.
Tikvah
1989 MCI-102 A3
HighTechRedneck
That is odd, cause it sure sounds like exactly what happens if the board section is "collapsed" using that  + or -.
There are other + or - 's to collapse other elements.  Are you sure we are looking at the same one?
Attached are two screenshots.  The one named "collapsed" has an arrow pointing at the one that does this and shows the effect it has on the view.
The other one shows some of the screen with expanded.
