Power steering ?
Power steering ?
Started by travelingfools, July 28, 2011, 09:43:17 PM
travelingfools
Can anyone suggest what type of fluid I should use for my steering ? Also, by tracing the lines, I assume the fluid goes in the coffee can size reservoir with the sight glass on the curb side of the engine.
87 MCI  9, 6V92 NJT
Tks
thomasinnv
Yes it goes in the coffee can sized apparatus on the curb side mounted just rear of the head. should be a fill spout mounted to the curb side of the intake air horn on top of the blower. You can use atf if it's the stock steering setup.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
If it is Sheppard, 15W-40 engine oil.  All others normal ATF. Look and see if your fluid is red (indicating ATF) or clear (could be hydraulic oil or engine oil).  Good Luck, TomC
travelingfools
Thanks all... it was atf.
