rear bath - Page 2
rear bath
Started by garrick, May 23, 2011, 03:26:09 PM
robertglines1
A separate toilet area when you add ladies to the mix (more than one at a time) is desireable. Maybe a makeup table as part of the bedroom area?
Joe Camper
If you want to install a rear bath without a macerator toilet you are looking for trouble. The run to the tanks in the rear bay where they normally should be, even if pitched more than usuall, will not always overcome a spot where the front of the bus is higher than the rear.
We have a rear bathroom I love it.
Macerators are very cool the discharge is on the side from there it goes back and up on a 45 degree, on top of the OTR A/C duct at the bottom of the wall and runs forward to the rear bay in front of the drives. Couldn't be easier to plum them you do not go thru the floor till you are directly over the tank. Find a spot and bolt it to the floor.
We also enjoy the knowledge that we never have any solids in the tank EVER.
I have a grandson that is capable of plugging a gravity dump right over the tank type toilet, if we had one of these in the rear we would be in trouble. :o
happycamperbrat
Quote from: robertglines1 on May 24, 2011, 04:00:36 AM
Personally, when traveling especially, I would prefere a desk to a makeup table. But whatever you guys do for your ladies, please make sure they have LOTS of good natural colored lighting where they do make up.
garrick
The plan would be to put in a half bath for quests, That way they stay more forward in the bus. It is just the wife and I,and she won't allow me to have any guests in the bedroom . The thought is with the rear bath I can have better access to the engine area, and with the bed farther forward the ride is better if sleeping while moving and less noise.
With lots of hard work and even more money some day I will be able to say I built that.1979 MCI 9 Plainfield IN.
