Left hand rotation 855 Cummins ? - Page 2
Started by 3408cat, April 15, 2011, 01:18:50 PM
rusty
I have an 855 big cam 400 in my 05. These are tuff motors I have 90,000 on this reman. I drive it hard all day long. To this day it does not use a drop of oil between changes. Clifford is rite about smoking at cold startup. I over come this by hooking my Aqua hot to the motor so I don,t have that problem. If I slow down to 65 I can get 6.8 miles per gallon.
Wayne
3408,
Of course you're right, I was thinking of the 903. The 855 series is probably one of the best engines ever made. I have one in my '71 Dodge 9000 truck tractor and have put many miles behind one in an Int 9670
3408cat
If the motor in the rear engine concrete truck that I spoke of is not left hand rotation, does the transmission have a different gear set up that changes rotation direction ? Is there a way to tell what model Allison is in the truck if it does not have a tag on it ?
