CO2 anti-runaway system ideas...
Started by LesBerg, March 23, 2011, 12:04:09 PM
The emergency shutdown as you call the air door was installed for 1 reason and that was to kill the engine when a injector stuck not allowing the engine to stop it never was intended to stop a run away engine and it won't
TedsBUSted
The emergency stop door door may not stop an engine completely, but, it will gag it to run slow enough so that it won't blow-up and can be otherwise stalled.
Luvrbus - How do you classify a runaway? Inhaling gas fumes for fuel?
The few I've seen take off on crankcase oil or uncontrolled fuel seemed to choke up around maybe three grand; still plenty fast in a cloud of smoke and noise.
I've heard that if they're inhaling gas fumes they can really buzz up the revs. I remember hearing a story about a broken natural gas line over-fueling a Jimmy, but I don't recall the details exactly. Actually two stories, one was a truck that knocked a gas meter off of a building, the other was a stationary engine that caught fumes somehow.
Ted
Bus polygamist. Always room for another, especially '04 or '06 are welcome. NE from Chicago, across the pond.
Ted a 4 stroke will do the same thing with natural gas I have seen the old Cat engines build up fuel and oil and run wild for a few seconds fwiw I had a 17A D-7 that was bad about it and it was a 1200rpm engine
Never have saw a DD runaway on crank case oil have saw a few get wild after days of idling
Tim Strommen
A diesel engine runs on compression - it stands to reason that a good method to stop the engine in a non-destructive way on a 2-stroke DD would be to have a valve that can vent the airbox after the blower, and bypass the buffer switch on a jake brake system.
Essentially, you'd wire a valve that would release the roots-blower/turbo pressure down to ambient or nearly ambient, then forcing the Jakes on (bypass the normal control circuits) would blow the pressure from the cylinders before they can support combustion - and would do so very rapidly...
It sounds a lot safer to me than having to carry a charged cylinder of inert gas on the bus.  This is similar to the system on smaller diesels that have the engine equivalent of a compressor's "unloader" essentially disabling the unit.
-T
Fremont, CA
1984 Gillig Phantom 40/102
