Rivets and Templates
Started by Highway Yacht, February 18, 2011, 12:26:41 PM
Highway Yacht
I'm getting ready to remove 8 stock windows and install the window skins soon. What did you guys use as a template to get all the rivets spaced out correctly and lined out in a straight row???  Also, have any of you ever used the "Drive Type" rivets where you use a hammer to set them?
Jimmy
Pete359EX
You could use peg board, like in your garage to hang tools on. Just pick your spacing, and dot with a sharpie.
Fred, 1986 Prevost XL, just beginning...Plans for roof raise, slide-outs, extension to 45', and maybe repower to CAT.
rv_safetyman
When I did my truck, I used an old wooden yardstick and drilled marking holes at the proper interval.  Then used a sharpie to mark each hole.
Worked great, but the drilling was not a lot of fun :o
I used the standard pop rivet (did not have to match any rivet on the truck).  If you go that route, you will need an air powered tool.
Jim Shepherd
Evergreen, CO
FloridaCliff
I bought a pantogragh rivet spacer from on-line.
Made the job super easy.  That and cleco's were money well spent.
http://www.aircraftspruce.com/catalog/topages/rivspacer.php
Cliff
Mark Twain
I just used a t square and made sure to always mark at the same measurements.  I put in over 1,000 rivets with one hole in the wrong location that was easily fixed.
