FAST IDLE DOES NOT ENGAGE
Started by coloradorich, February 06, 2011, 09:07:04 AM
rv_safetyman
Nellie, if there is a Schrader valve that is connected to one of the tanks (hopefully the wet tank), that would be fine.  The issue with Schrader valves is that most air chucks do not lock on the valve.  You can buy special chucks that do that, but I would be tempted to replace the Schrader valve with a female quick connect.
I don't think Eagles came with Schrader valves, and can't speak for other buses.
Bottom line, the very first Rich should take is to find a way to hook up an auxiliary compressor.  That would really speed up trouble shooting.
Jim Shepherd
Evergreen, CO
coloradorich
I have a compressor that I use to air up my tires, will connect it at the back when weather permits it is now two degrees and droping. We live in our bus full time and are at an RV Park while we purcase some land in the mountains. Will keep you all posted if I find anything.
" Downhill Flyer Gravity is our Friend "
rv_safetyman
Sounds like a plan.  I hope our weather in Evergreen/Denver heads you way.  Supposed to be in the '60s this weekend.
Jim Shepherd
Evergreen, CO
Nellie Wilson
Jim -
Excellent point: "The issue with Schrader valves is that most air chucks do not lock on the valve."  See, that's the kind of stuff I don't consider... it's why I persist in opening mouth and inserting foot. Plus I didn't realize we were talking Eagles (read, Nellie, read!) :-[
Hey, Colorado, snoop around Buena Vista. Check out Cottonwood Hot Springs: Hippyish but wonderful (you can park there). Five springfed pools (varying temps), tons of wildlife (besides humans) and GREAT fishing nearby. And, after dark, the pools are clothing optional  ;). Wanna show off? Just get to your neighborhood tanning salon (suddenly realized why BO taxed these places).
The area is absolutely gorgeous and virtually unchanged in many years. If you find a chunk of land let me know! Heck, let us all know.
Nellie
Had to change a tire... >:(  got to put it on backward... :-\  still trying to fix it on photoshop... ??? ::) ???
coloradorich
nellie
Buena Vista sounds great but to far and snow is deep. Found and am buying 5 acres in the Sangre De Cristo Mountains at 8650 ft.
Nellie Wilson
Hey Colorado -
As I recall, Sangre de Cristos are in southern Colorado... somewhere west of Trinidad. That area is gorgeous and has one of highest wildlife populations in the U.S. Pretty decent weather too. Maybe that's why all those outlaws  :o hung out around there?
Good for you... sounds a good plan!
Nellie
Ed,
Thanks, that is good to know, but hasn't ever happened to me. Now I know!!
