Replace front crank seal on 8V71
Started by bevans6, January 30, 2011, 09:09:10 AM
Is there any reason  I can't change the front crank seal on an 8V71 without removing the front cover?  manual says remove front cover, which I really would rather not do.  Seems to be lots of room and it fits from the outside, once the spacer is removed.
thanks, brian
I found in the manual that you can change the front seal without taking the cover off except for front covers with trunnion mounts.  What is a front cover with a trunnion mount, and why can't you change the front seal on them?
lostagain
When I overhauled my 4-71, I changed the front seal without removing the front cover IIRC. Why don't you try it. You got nothing to loose. If it doesn't work, then remove the cover.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
