88 Eagle entertainer no engine C-list
Started by eddiepotts, January 12, 2011, 07:44:31 PM
eddiepotts
Quote from: eddiepotts on January 12, 2011, 07:44:31 PM
I have not seen it. it could make a good starter. http://houston.craigslist.org/rvs/2153293928.html
I thought if the engine was out of it, it wouldn't start. ;D
jest kid'n!
If the price is right,that is a 102 wide model 15 with the factory raised roof doesn't appear to be a high driver probably made with Cor/Ten steel just will be minor rust sides look good and one thing about Eagle you can install about any engine in those buses and that one will probably have a hydraulic fan for cooling makes for easier engine swaps.Check it guys was more than likely never a seated coach for Trailways or Greyhound
