Aluminum roof coil siding/skinning - Page 2
Started by kpatchen, October 21, 2010, 07:33:06 AM
Marcos, a Eagle is not a MCI totally different construction ,steel for a Eagle been there done that with fiberglass from R&M on a Eagle looks like crap in the heat here in AZ
DMoedave
The fiberglass is not that light is it? The 4x8 sheets i have worked with in the past were heavy. I think they were 3/16 thick.
we love our buses!!! NE Pa or LI NY, or somewhere in between!
Ericbsc
I used 16' long sheets of t6061. Joints are milled to be completely flush. Slight bow in middle for strength. As Clifford said it is tough to keep flat.!! The sun heats up the sides quick. I have some movement even after foam.
Ericbsc
This is the .060 3036 after heated and streached.
This is after the foam warped it. Look slose to see buldges in skin.
