Eagle owners
Started by wal1809, September 07, 2010, 05:33:37 AM
wal1809
I am hoping to hear from Eagle owners or people that know about Eagles on this one.   I have a question on how your Eagle is set up.  On the driver side above the foot pedals under the dash my eagle is open.  For clarification--- Air rushes past my toes goes under the dash and escapes to the outside, a lot of air.  Air that I consider precious is escaping and I don't like it.  I like it so little I sweat over it.  SO my question is how are your Eagles set up to stop this?  I am thinking of some sort of flat pplastic piece and taking it to get it covered with the same stuff the dash is covered in.  Then making a snap in type of system where I can take it out in the event I need to access under the dash.  I just wanted to know if yall had something already inplace or in mind.
www.snakebreaker.com
Wayne, most use carpet from the heater core back to the drivers window but first you have to install new seals around the electrical panel door some just have the seal on the bottom needs to be on all the frame Jefferson has it.
Next buy you a few sticks of the foam pipe wrap cut a piece and place it at the very front of the panel where the wires enter the coach then remove the front bumper blade at the top replace the insulation above that most of time people have removed it that should stop your air drafts
