Thinking about building a small Diesel DC powerplant - Page 5
Started by Zeroclearance, June 08, 2010, 10:46:30 AM
Hal
Kind of late to this thread I'm afraid but thought this might be of some interrest. About two years ago when fuel was almost $5 a gallon, I started a DC genset project. I  sourced a single cylinder Kubota, water cooled double balance shaft diesel. I'm driving a 200 amp 12 volt alternator, using a Zantrex 3 stage regulator with battery heat sensor. I plan on running at 2000 rpm, @150 amps to charge the battery bank. I have a heat exchanger to heat domestic water through my marine water heater (double walled of course). I have a Trace SW2512 which has load sharing so running a single air should be possible. Kubota claims a fuel usage figure of 8 hours per gallon at rated load. The sound box is on the drawing board using Bob Belters' design and will be quiet enough to run without anyone hearing a thing outside the bus.That's the plan anyway. Just need to get the time to finish it. :D
Hal
1974 Eagle, 102",45", lifting rear tag, single slide, 14ltr pre egr Series 60,world trans.
1977 GMC fwd MH, converted to diesel with 4sd auto
1975 FMC Duramax/Allison conversion in progress
would an engine like this be a good choice for a DC power plant?  I am thinking of a single DN50 alternator, running the engine around 2000 rpm.
http://www.dieselenginemotor.com/diesel/engines/4179,1.html
Zeroclearance
Hal, Thanks for posting your experiences.
Brian, I have looked at the single cylinder diesels and have come down to conclusion that for smooth quiet running I need to purchase a small 3 cylinder Yanmar or Kubota.
I have received a few PM's from this email for updates.   I have purchased my 400 amp 24V alternators and need to write out a check for the powerplant.
Brian-that little 3 cylinder engine would be perfect! Quiet, smooth, long lasting.  Good Luck, TomC
Hal
The single cylinder Kubota I bought uses double balance shafts and is remarkably smooth for a single. It is limited in hp and wouldn't work in your application but should work for my modest wattage requirements. The primary use is to charge batteries as running a 20k genset 3+ hours a day with limited load (without air of course) makes little sense. $12 to $15 a day to keep the refer going vs $1.50 makes it  practical. Hal
NewbeeMC9
Quote from: Zeroclearance on July 09, 2010, 10:46:34 AM
I this the two 200 amps with a fancy dual controlling regulator or what did you end up with?
Pics-pics!
Pretty-Please!!
Kenny
1941 and 1945 Flxible - South Lyon, Michigan
