8V71 air box blower
8V71 air box blower
Started by BJ, July 23, 2010, 08:33:55 AM
BJ
this is going to be interesting question. But, I have a leak in my reduction gear box on my air box (fans)  I have witnessed several of these being removed with much work and cussing. Has anyone used instead of oil a good quality grease?
Those are oiled from the engine the 1/4 inch tube on the rear is the supply then it dumps back to the engine at the front I have no idea what you are calling fans
Fredward
I think he means the fan drive gearbox for the engine cooling squirrel cage fans?
Fred Thomson
Why would he post 8v71 air box blower ? this one is not real clear to me  lol
BJ
OK squirrel box fans that blow air sucked through the radiators onto the engine. And no they are not oiled from a tube. The seal is leaking and these can be a real pain in the a-- to remove, blower fans and reduction drive gearbox.  I hope that clears up what I called air blowers (they do blow air) sorry about that....Can anyone answer the question I posted?
yea they used gear lube for a reason inclosed gears in a mitre box don't get along with grease
BJ
 :-\  well shucks I guess I will have to keep a real close eye on the oil level glass..thanks
kyle4501
There are some snake oil seal conditioners that will swell up the seals & may slow down or even stop the leak for a short time - if it is a seal leak.
Might help with the leak until you can fix it properly.
BJ
Kyle I tried diesel fuel trying to swell the seal, no go. It is not major but if you don't check it and add oil @ fuel up you might have problems  >:(  It is a major job to just get the fans off the shaft on a bus this old..... :'(
kyle4501
Usually, the liquid mechanics don't do quality work anyways.    ;)
BJ
 ::)  ::)   no but they work cheap.................. ;D
The mess being blown around by the fans can be called rust proofing.
Call it a day?
BJ
 ;D  ;D  ;D  buswarror     lol..............
