Water Temp Gauge 4106
Started by Madmike, July 18, 2010, 01:29:41 PM
Madmike
My water temp gauge does not work. I have checked the wires but I don't see anything wrong with it. It is the original gauge. Is there a way to test it?
You can have this bus when you pry her from my cold dead fingers.
Madmike
I also do not know it the engine hot light works is there a way to test it?
Hot engine light may be tested by grounding the lead from the appropriate sensor mounted in the thermostat housings.
You have two thermostat housings, you need to take inventory on what might be mounted in each side.
There might be one for the temp gauge, and one in each side for the hot engine signal, or....?
