Where to get inexpensive foam bunk mattresses?
Started by belfert, August 16, 2006, 11:08:36 AM
Any suggestions where to get inexpensive ($100 or so) foam bunk mattresses?  I am thinking about the type they would use in a cabin/bunkhouse at a youth camp.  They do need to be 80" long instead of the standard twin length.
I bought one from Excel Distributing for $88 that is nice, but not firm enough.  Knox Foam is simply too expensive by the time you add a cover.
Brian Elfert
Brian if you don't have any luck with what you are looking for I can think of a couple of other places to buy cheap mattresses ! Either at a Big Rig/RV Salvage yard, or at one of the RV Surplus outlets over around Elkhart/Southbend, IN area ! They'll be more like a  real mattress than just a foam pad but you probably can get the size your looking for at a reasonable price ! FWIW BK ;D
Ncbob
Brian...we followed the recommendation of Cliff (Florida Cracker) and contacted Knox foam (they're online) and ordered ours.
FWIW.....
Bob
Quote from: Busted Knuckle on August 16, 2006, 01:22:58 PM
I actually couldn't seem to find any decent bunk mattresses at any of the RV Surplus places in Elkhart back in April.  Very little selection.
Fuel is too expensive and time is too precious to make another trip to Elkhart right now.
Brian Elfert
RTS/Daytona
see--> http://www.walmart.com/catalog/product.do?product_id=3380079
reversable - memory foam on one side - firmer regular foam on the other
cut the king size (76" x 80" X 6") in half  --> yields (2) 36" x 80" X 60" -
we like them in our RTS
Pete RTS/Daytona
Quote from: belfert on August 16, 2006, 02:24:14 PM
Brian Elfert
They have phones and some have websites, doesn't cost much to check it out before dirving all the way there ! Also don't forget to check out the big truck places the mattresses in the sleepers are about the size you were looking for if I remember right !  BK  ;D
I've probably built a half dozen foam mattresses over the years.
I use two pieces. One is 2-3" thick of medium firm, the base is 4-6" of very firm. I put these two together inside a padded  mattress cover with the softer one on top so it will have enough give to conform to body shapes. The very firm is the base with little give. Of course the platform for the mattress must be solid, I use 3/4" plywood.
This works just as well as the overpriced "memory" foams.
I just did one like this for the bus.
I buy all of my foam from JC Penny mail order. The quality is first rate and the price is reasonable.
pvcces
Thanks, Gusc, we're in need of some foam cushions. We'll be checking that source out.
Tom Caffrey
Suncatcher
Ketchikan, Alaska
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
JerryH
Bought ours from Katz in Phila.
Katz Foam & Fabrics
857 N 5th St, Philadelphia, PA
9.5 mi NE - (215) 922-3290
These guys were GREAT!!  They do ship, but I drove there -- I am outside Phila.
They took a queen size 5" foam mattress and cut it to the size I needed for (2) bunks.
I cannot remember the exact price, but it was very very afordable.
They have a catalog as well.  They sell spray adhesives and everything you need for upholstery work.  Very reasonable.  They only do cash or check -- No credit cards.
Jerry H.
