First day of summer was not a good one....
Started by Oregonconversion, June 22, 2010, 11:25:45 AM
A no hub clamp may work better for you there is a difference in no hub and a Fernco the no hub is wrapped in stainless steel with 2 bands and needs to have the right torque on each end it is a good clamp used in commercial building to join cast iron pipe
wal1809
There are just some pictures we should not see before the third cup of coffee ;D
www.snakebreaker.com
kyle4501
Since nothing will stick to it, use some coarse sand paper to rough up the surface - then the rubber sleeve or goop of choice will have a mechanical 'tooth' to hold onto.
What a crappy project . . .
