How to Adjust 4601 Door
Started by Madmike, June 07, 2010, 01:38:34 PM
Madmike
How do you adjust the door. It will not stay closed and when you pull it shut with the lever on the dash you can push it open. I know it can't be hard but i can't find it in the manual.
You can have this bus when you pry her from my cold dead fingers.
Sam 4106
Hi Madmike,
There is a turnbuckle under the dash on the passenger side. It is accessable from the compartment where the fire extinguisher is stored. The locknut on mine came loose and the linkage got out of adjustment. So be sure to tighten the locknut when you get it adjusted.
Good luck, Sam MC8
kyle4501
On my 4501, the adjustment is found by opening the 'fire axe' door (on the right as you enter the coach) & reaching up towards the dash.
