Spicer 4 speed wet to dry clutch question
Started by bryanhes, April 06, 2010, 11:24:06 AM
bryanhes
In my 4905 I have a wet clutch Spicer 4 speed. I hear about 4 speed spicers in other buses as well. From my understanding these are a dry clutch.
My question- Is it possible to turn a wet clutch into a dry clutch? I know this is open to wise cracks,  ;D but humor me  ;)
If this could be done I would not mind shifting so much as the dry clutch seems to shift easier.
Bryan
LUKE at US COACH
Hi Bryan & Folks:
Yes it can be done.
You will need a replacement, transmission, flywheel and 15" double disc clutch assy. & shift & clutch rods.(You may be able to modify your rods).
Best bet would be to find someone parting out a 4106 which would have everything you need.
I Hope this HELPS!!!
Happy & SAFE!! Bussin' to All.
LUKE at US COACH
LUKE at US COACH
rdbishop
bryanhes
Richard,
The more I think about it the more I feel I am loosing fuel economy and cruising speed with the auto. As most of the time is spent in fourth anyway. If it shifted and went into gear with less effort I would be fine with it. Just thinking out loud at this point. When we were working on the 7 it just slipped into gear so much easier than the wet clutch. That is what got me thinking about it.
Bryan
wildbob24
Bryan,
If you decide to go that route, I've got a 4106 transmission, flywheel. and clutch assy that will fix you right up. PM me if you're interested.
Bob
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
