Buffalo Shower Ideas
Started by BC Bus, February 12, 2010, 01:48:04 PM
BC Bus
I am looking for pictures of showers in your GMC Buffalo. I have decided
against using ceramic tile so am looking for ideas for using shower wall panels
or cutting down a ready-made stall to fit the curve of the roofline.
Pictures would be great but any ideas that have worked would be welcome.
GMC Buffalo  &  MC9
Always willing to help a Busnut !
crown
not a buffalo but round roof i cut and fiberglased it to fit then painted it with auto paint
before & after pics i under stand tile is ok if you use a flexable grout
john
57 crown
costa rica
Tom Y
BC, I put plastic on my ceiling then cut the shower stall to fit. This pic is before I put silicone caulk around it. Tom Y
Tom Yaegle
crown
 tom i am going to put up fiberglass over shower allso thanks
john
57 crown
costa rica
Bill B /bus
Why not tile?
Put a ceramic tile shower in a Buffalo in 1995 and its still in great shape today, with its second owner.
Bill
Bill & Lynn
MCI102A3, Series 50 w/HT740
BC Bus
Tom Y,
I really like your idea...do you happen to know what shower stall you  purchased (model number, brand), where, and what size are you putting in.
Thanx
Bill in Portland OR
GMC Buffalo  &  MC9
chris4905
BC,
Pictures of the shower in my 4905.
The pan is a purchased 32"x32".
I used fiberglass to cover the wood walls of the shower.  I believe I just used liquid nails to glue it to the wood and the building the rest of the shower allowed screws through the fiberglass in several areas to reinforce it to the walls.
I checked into buying pre-made glass shower panels and cutting them to size, but they are hardened for safety, and having a manufacture cut them to size, or customer make them, was too expensive for me.
Soooo.....I bought some clear (I believe 1/4") lexan panels.  The cost was not bad at all.  Lexan is very tough but you can cut it with a saw blade and also drill it with a drill bit.
I got some 1/4" aluminum channel, drilled and attached it to the fiberglass, then placed the lexan into the channels and side drilled and attached with stainless screws and nuts.  I hope that makes sense.
I have attached pictures and if you have questions please don't hesitate to ask.
Chris
Chris & Cheryl Christensen
Ex-Bus Owners
Eagle, Idaho
chris4905
More 4905 shower pictures.
I also have a closeup of the door closure knob if you want it.
Chris
Ex-Bus Owners
Eagle, Idaho
crown
 just saw a did not post before picture hear it is
john
57 crown
costa rica
Tom Y
BC, I will look. I think it is 36x36 but it may be 32x32. I bought it at Lowes, a 4 peice I think made by Sterling. Tom Y
Tom Yaegle
