Quest Fittings Question
Started by gus, February 02, 2010, 09:44:02 AM
I've never used Quest fittings before but will need to when I install my new water pump.
What is the purpose of the small metal washer underneath the nylon ring into which you push the pex line?
Once tightened, can the pex line be removed by just loosening the large nut?
Just Dallas
