Throttle cable question
Started by Charles in SC, January 06, 2010, 06:52:24 PM
Charles in SC
I am wondering if I can lube the throttle cable on my 5303. When I do not use it for a while it seems to stick. This has not created a problem but I do not want it to break. Any ideas?
Had the same thought a while ago, found out the throttle and shifter cables( on my eagle) are what they call perma -lubed. Might be the grease or what ever is loaded in the cable thickens at low temps ;)YMMV
