Fan Drive
Fan Drive
Started by damman, September 23, 2009, 07:59:48 AM
damman
I have a bell shaped cast iron fan drive that is 11" diameter on the mounting end.It is 8" long and has a fan mounting flange on the small end.It has clutches inside that are worn out.the name on the tag is worn off.Can anyone tell me what the name is?Can i get parts for it?It is on a 692 Detroit.The part number is 0949.
roger dolan
   What kind of a bus is it?
Sounds like the torus fan drive for a V drive.
Engine oil pressure regulated via a thermostat varied the fan speed.
damman
The fan drive is on a 692 detroit which was put in a 4107 GMC replacing the 871.It is not a torus drive.The housing is smooth with no ribs.
gm4106
Any way you can get us some pictures?
GM PD4106-1689 8V71TA  V730
Mount Holly,NC
damman
 :)Yea! I found out that it is a Force Controls Industries Fan Drive Assembly and that I can get rebuild parts for it.Thanks for all the help.I can soon get back on the road once I finish swapping out my old fried engine.
