roof leak, oil leak and coolant leak
Started by Adarian, October 25, 2009, 12:31:57 PM
Adarian
Looks like I have an oil leak coming from the oil filter seal.
Also a coolant leak coming from a hose connected to the thermostat housing.
They will be next on the list of things to fix along with the leaks from the roof where the emergency vents are.
Trying to figure out how to dry out the foam in the roof? I can here the water squishing when I walk on the roof.
That is how I learned the emergency vents need to be sealed.
1978 Gillig 636D
CAT 3208 Allison MT 643
NLAAF Fitness Bus
Fair Oaks Ca
