Jump starting a 24 volt MCI 9
Started by johns4104s, August 30, 2009, 09:14:54 PM
johns4104s
How do you go about jump starting a 24 volt MCI 9?
Also are there very many other coaches with a 24 volt system? Does Prevost or Van Hool have 12 or 24volt systems?
both have 24 volt for the main system.
johns4104s
Luvrbus,
What does your Eagle use?
12 volt, John how many batteries do have if just 2 find the low one and jump it with 12 volt just don't try and jump 2 together
Quote from: luvrbus on August 30, 2009, 09:35:42 PM
Why not?
As it happens my bus has four 6v batteries so I couldn't just jump one anyway, but I cannot think of any reason why you shouldn't jump the whole lot using two batteries
NewbeeMC9
I jump mine from the house batteries,   Just turn the switch to the BOTH position. :)
John316
Ours is 24 volt. If I needed to jumpstart ours, I would disconnect the batteries, and charge them at 12V. After they were done, I would hook them back up.
God bless,
guys I  was telling him how to jump his 24 v with a 12v if you connect to one battery you are ok but if connect with all the batteries at the 24v end not ok 12v and 24 v don't mix but one 12v at a time in the group is ok and most of the time jumping one will start the bus.
two inexpensive battery chargers are a valuable addition to the busnut arsenal.
attach each one to a battery in the traditional manner, simply focus on one battery at a time,
one extension cord will run them both.
start bus in a few hours, or in the morning.
No need to disconnect anything with tools, just pull the battery switch in order to maximize your efforts.
John316
I see, Clifford. Makes sense.
God bless,
You need two jumper cables and two separate batteries.  Then hook up to the bus batteries separately, like they are wired, and you have 24v available for jumping.  Even on my 12v truck, it has 24v series/parallel switch that you also need to hook up two sets of batteries with two jumper cables to get the 24v.  My '79 Olds Diesel was wonderful for this since it has two starting batteries.  Good Luck, TomC
Jerry32
I found  a 24 charger with a built in timer that works for me quite well. I can charge house and coach batteries at the same time or just the house batteries alone. I can also use the inverter charger the same way. I would just  aaaaaaaaaaaaaaaaaaaaaaaaamake up a 24 battery and use a set of jumpers to connect. Jerry
1988 MCI 102A3 8V92TA 740
johns4104s
So you would take the two batteries out of the circuit and jump two in making sure to include the pos to neg jumper, Correct? So its not possible to add anything to the original low batteries, Right?
Don4107
If you have two donor rigs and two good sets of jumper cables you can hook one to each battery.  Make no connection between rigs and be sure the bodies are not touching.  As with any jump, let the donor rigs charge for a while at fast idle.
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
